Ana içeriğe geç
Sony FDL-220R Watchman Speaker Replacement
Neye ihtiyacın var
  1. Sony FDL-220R Watchman Speaker Replacement, Remove battery cover and batteries: adım 1, 2 resimden 1. Sony FDL-220R Watchman Speaker Replacement, Remove battery cover and batteries: adım 1, 2 resimden 2.
    • Press down on the textured area and push toward the bottom of the device.
    • Gently remove the battery cover.
    • Remove the three AA batteries.
  2. Sony FDL-220R Watchman Speaker Replacement, Remove screws: adım 2, 2 resimden 1. Sony FDL-220R Watchman Speaker Replacement, Remove screws: adım 2, 2 resimden 2.
    • Locate the five 5x11mm screws surrounding the battery compartment.
    • Remove screws with a Phillips #00 screwdriver.
  3. Sony FDL-220R Watchman Speaker Replacement, Remove back casing: adım 3, 2 resimden 1. Sony FDL-220R Watchman Speaker Replacement, Remove back casing: adım 3, 2 resimden 2.
    • Grasp the entire back half of the Watchman's casing.
    • Snap off the casing from the bottom of the device.
    • Gently pull off entire back casing.
    • Buttons may fall out upon opening casing. See the button replacement guide to fix buttons.
  4. Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: adım 4, 3 resimden 1. Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: adım 4, 3 resimden 2. Sony FDL-220R Watchman Speaker Replacement, Remove circuit board: adım 4, 3 resimden 3.
    • Carefully grasp the entire circuit board.
    • Pull the circuit board off of the device's plastic casing.
  5. Sony FDL-220R Watchman Speaker Replacement, Remove speaker: adım 5, 3 resimden 1. Sony FDL-220R Watchman Speaker Replacement, Remove speaker: adım 5, 3 resimden 2. Sony FDL-220R Watchman Speaker Replacement, Remove speaker: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • Locate the mono-speaker on the device.
    • Locate the two through-hole contacts to the right of the speaker.
    • Touch a soldering iron to the two through-hole contacts.
    • While the solder is hot, pull down on the wire with tweezers.
    • It may be helpful to remove excess solder with a solder wick or sucker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sam Putnam
484 İtibar
4 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-5, Williams Fall 2014 Baylor, Team 4-5, Williams Fall 2014 üyesi
BU-WILLIAMS-F14S4G5
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 6
Her zaman: 332
