Giriş
This guide will take you through the steps needed to replace the charging port on your Sony H.ear On 2 headphones. The charging port is located on the bottom of the left ear cup and could need replacement if it is faulty or damaged. This repair will be relatively simple and requires that you to remove one screw and ribbon cable to replace the input/output (IO) board containing the charging port.
Neye ihtiyacın var
Start by inserting the iFixit plastic opening tool in the crease between the hard plastic and the ear cup, and then gently apply pressure until it separates. You may need to repeat the process on back until it is completely separate.
Unscrew the single 6.4mm screw holding the IO board / charging board in place using the same JIS #00 screwdriver.
Lift out the board carefully, allowing the port to slide out of its holding easily.
7 farklı kişi bu kılavuzu tamamladı.
5 Yorum
How much internal space is there inside the left ear cup? I’m considering attempting to mod my pair with a qi receiver possibly at the expense of the NFC chip.
I cannot locate the IO board online. Is there somewhere you buy this board?
I have the same question Jonathon, IO board is nowhere to be found online :/
The IO board looks to be part A-2182-326-A = "Sony L Jack Mounted Pc Board (Uc)". Is that correct?
