Ana içeriğe geç
Sony H.ear on 3 Right Ear Pad replacement
Neye ihtiyacın var
  1. Sony H.ear on 3 Right Ear Pad replacement, Extend the Right Speaker: adım 1, 2 resimden 1. Sony H.ear on 3 Right Ear Pad replacement, Extend the Right Speaker: adım 1, 2 resimden 2.
    • Extend the Right cup and fold the Left cup away via the headband .
    • This will help protect the other ear pad while you work on this one.
  2. Sony H.ear on 3 Right Ear Pad replacement, Unclip the Right Ear Pad: adım 2, 3 resimden 1. Sony H.ear on 3 Right Ear Pad replacement, Unclip the Right Ear Pad: adım 2, 3 resimden 2. Sony H.ear on 3 Right Ear Pad replacement, Unclip the Right Ear Pad: adım 2, 3 resimden 3.
    • The pad is attached by 6 clips in a hexagonal pattern, shown by the arrows.
    • Starting from the top, insert an opening pick in between where the cup leather meets the plastic casing, push it in firmly, then twist it until you disengage the top clip.
    • Try not to damage or peel off the leather while doing this. It helps if you pry towards the speaker housing, not the leather cup.
    • Work round the back side, poking the pick in and twisting to disengage further clips until you can gently pull the cup away.
    • When re-assembling, make sure that the stitching line on the ear pad is facing the bottom.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Caius Nocturne
2.076 İtibar
13 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 1,048
