Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
The user will learn how to disassemble the Sony CX260V Handy cam down to the point where all the main internal issues are accessible. There happens to be a lot of prerequisite steps before you can start to repair the device.
Neye ihtiyacın var
Set up the camera in a clear, open, clean and professional work space. Make sure you have all the necessary tools.
Using the Phillips Head #00 size screwdriver, unscrew the two 5 millimeter screws located on the top left and bottom of the join attaching LCD screen to the device.
Using the same size screw driver unscrew the 3 millimeter screw located in the middle of the joint assembly; attaching the LCD screen to the device.
Next, unscrew the two five millimeter screws located on the left interface of the camera that the LCD screen rests on. (Should be located where the USB jacks are.)
Locate the battery assembly, on the top of the camera and unscrew three screws; two 5 millimeter screws and one 3 millimeter.
Using the PH #00 size screw driver, unscrew a 5 millimeter screw located on the top left near the lens of the camera.
Using a pair of tweezers, carefully disassemble the two wires connected to the bottom motherboard portion of the camera.
One white & black wire and one flat yellow wire are connected to the lens pane.
Using the screwdriver, locate the three five millimeter screws. Carefully remove the camera lens with your hands or spudger tool.
One is located on the bottom of the lens area, and the other two located on the top left and right of the lens area.
Unscrew one silver 5 millimeter screw from the front right side of the camera, located where the orange mother board card is.
Unplug the wire. Underneath will be another silver five millimeter screw.
Using tweezer, release the clip attaching the main internal system to the main frame on the bottom of the camera. Allows the rest of the camera to be freely taken apart.
The side panel will have cords running through the frame; unplug these and frame will be removable.
2 farklı kişi bu kılavuzu tamamladı.
