Ana içeriğe geç
Sony Handycam CX260V Internal Speaker Replacement
Neye ihtiyacın var
  1. Sony Handycam CX260V Internal Speaker Replacement, Sony Handycam CX260V Housing Disassembly: adım 1, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the one 3mm and two 5mm screws located in the battery assembly area.
  2. Sony Handycam CX260V Internal Speaker Replacement: adım 2, 1 resimden 1.
    • Remove the two 5mm screws located on the top left and bottom of the camera.
    • Remove the 3mm screw located in the middle of the joint attaching the LCD screen to the device.
  3. Sony Handycam CX260V Internal Speaker Replacement: adım 3, 1 resimden 1.
    • Remove the two 5mm screws from the panel to the right of the LCD screen.
  4. Sony Handycam CX260V Internal Speaker Replacement: adım 4, 1 resimden 1.
    • Use the plastic opening tool to remove the cover for the recording buttons.
  5. Sony Handycam CX260V Internal Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the five 5mm screws located on the bottom panel.
    • Remove the bottom panel covering the internal motherboard.
  6. Sony Handycam CX260V Internal Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the 5mm screw located by the lens and two 5mm screws located under the handle.
    • Remove the leather strap from the device.
  7. Sony Handycam CX260V Internal Speaker Replacement: adım 7, 1 resimden 1.
    • Remove the 5mm screw to the left of the Record button.
    • Remove the entire right-side panel where the leather strap was located.
  8. Sony Handycam CX260V Internal Speaker Replacement: adım 8, 1 resimden 1.
    • Use a spudger to remove the LCD joint cover.
  9. Sony Handycam CX260V Internal Speaker Replacement: adım 9, 2 resimden 1. Sony Handycam CX260V Internal Speaker Replacement: adım 9, 2 resimden 2.
    • Remove the three black 5mm screws and one silver 4mm screw located on the front right-side of the camera, near the orange motherboard.
    • The silver screw is located on the front right-side of the camera and is attached to the main panel.
  10. Sony Handycam CX260V Internal Speaker Replacement: adım 10, 1 resimden 1.
    • Remove the 5mm screw located on the top left near the camera lens.
  11. Sony Handycam CX260V Internal Speaker Replacement: adım 11, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers, carefully detach the two wires connected to the bottom motherboard portion of the camera.
    • One white wire, one black wire, and one flat yellow wire are connected to the lens panel.
    • Remove the lens panel.
  12. Sony Handycam CX260V Internal Speaker Replacement: adım 12, 1 resimden 1.
    • Remove the three 5mm screws.
    • One is located at the bottom of the lens area, and the other two are on the top left and right of the lens area.
    • Carefully remove the camera lens with your hands or a spudger.
    • There are three springs located underneath the lens. Make sure to not lose them.
  13. Sony Handycam CX260V Internal Speaker Replacement: adım 13, 1 resimden 1.
    • Remove one 5mm screw located on the back left section near the zoom and picture control capturing button.
    • There are two flat blue wires keeping the buttons connected to the main assembly. Carefully set them aside or unplug them.
    • This partially removes the zoom and picture capturing control.
  14. Sony Handycam CX260V Internal Speaker Replacement: adım 14, 1 resimden 1.
    • Remove one silver 5mm screw located near the tripod mount.
    • Remove the tripod mount screw that has the mount assembly underneath.
  15. Sony Handycam CX260V Internal Speaker Replacement: adım 15, 1 resimden 1.
    • Remove the silver 5mm screw located on the front right side of the camera by the orange motherboard.
    • Unplug the wire.
    • Remove the silver 5mm screw underneath the wire.
  16. Sony Handycam CX260V Internal Speaker Replacement: adım 16, 1 resimden 1.
    • Using tweezers, release the clip attaching the main internal system to the mainframe. This allows the rest of the camera to be freely taken apart.
    • The side panel will have cords running through the frame. If you unplug these, the frame will be removable.
  17. Sony Handycam CX260V Internal Speaker Replacement, Internal Speaker: adım 17, 1 resimden 1.
    • Using the screwdriver remove the two black 5mm screws located on the side of the speaker.
  18. Sony Handycam CX260V Internal Speaker Replacement: adım 18, 3 resimden 1. Sony Handycam CX260V Internal Speaker Replacement: adım 18, 3 resimden 2. Sony Handycam CX260V Internal Speaker Replacement: adım 18, 3 resimden 3.
    • Gently remove the red and black wire connected to the mother board with the tweasers.
    • Remove the tri color wires from the mother board. (Has a white connection)
    • Unplug the orange flat wire located at the bottom of the camera.
    • Removes the Internal Speaker
  19. Sony Handycam CX260V Internal Speaker Replacement: adım 19, 2 resimden 1. Sony Handycam CX260V Internal Speaker Replacement: adım 19, 2 resimden 2.
    Satın Al
    • Using a screwdriver remove 5mm silver screw located in the inner back by the battery component holding down a chip.
    • Removes the Microphone Jack
    • Using the tweezers, remove internal speaker.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Austin King
101 İtibar
1 Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 206
