Giriş
Occasionally the LCD screen or the Back light on the camera will be cracked or simply stop working. This page outlines how to disassemble the camera in order to install replacement parts for any broken pieces.
Neye ihtiyacın var
On the back of the camera beneath the viewfinder, locate the battery pack.
Press the small button.
Slide the switch forward.
Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
Remove the copper strip from the housing that connects the outer casing to the entire of the camera.
Remove (4) 2.9mm screws from the L-shaped circuit board. They are marked with red circles in the slide.
Remove the (3) wire strips connected to the camera so you can pull off the L-shaped circuit board.
Remove the single wire strip that is connected to the bottom of the circuit board.
Bir başkası bu kılavuzu tamamladı.
