Ana içeriğe geç
Sony Handycam DCR-DVD103 Outer Cover Replacement
Neye ihtiyacın var
  1. Sony Handycam DCR-DVD103 Outer Cover Replacement, Battery: adım 1, 1 resimden 1.
    • Images do not show the camera's battery.
    • On the back of the camera beneath the viewfinder, locate the battery pack.
    • Press the small button.
    • Slide the switch forward.
  2. Sony Handycam DCR-DVD103 Outer Cover Replacement: adım 2, 1 resimden 1.
    • Remove the battery from the camera.
    • To reinsert the battery, slide the battery into the camera.
  3. Sony Handycam DCR-DVD103 Outer Cover Replacement, Outer Cover: adım 3, 1 resimden 1.
    • Using a #00 Phillips screwdriver, remove the six 4.5 mm screws from the camera's bottom.
  4. Sony Handycam DCR-DVD103 Outer Cover Replacement: adım 4, 2 resimden 1. Sony Handycam DCR-DVD103 Outer Cover Replacement: adım 4, 2 resimden 2.
    • Remove the three 4.5 mm screws beneath the battery.
    • Remove the 2.9 mm screw from the right corner.
    • Remove the two 4.5 mm screws from the battery's right wall.
    • Images do not show the battery.
  5. Sony Handycam DCR-DVD103 Outer Cover Replacement: adım 5, 1 resimden 1.
    • Remove the 4.5 mm screw under the output flap on the front of the camera below the lens.
  6. Sony Handycam DCR-DVD103 Outer Cover Replacement: adım 6, 2 resimden 1. Sony Handycam DCR-DVD103 Outer Cover Replacement: adım 6, 2 resimden 2.
    • Remove the two 4.5 mm screws at the top of the camera.
    • Remove the 4.5 mm screw from the disk side of the camera (next to the lens).
  7. Sony Handycam DCR-DVD103 Outer Cover Replacement: adım 7, 2 resimden 1. Sony Handycam DCR-DVD103 Outer Cover Replacement: adım 7, 2 resimden 2.
    • Extend the gray viewfinder, then gently remove the black plastic casing.
    • Caution: Plastic pieces are fragile.
  8. Sony Handycam DCR-DVD103 Outer Cover Replacement: adım 8, 1 resimden 1.
    • Remove the two 2.9 mm screws under the black plastic casing.
  9. Sony Handycam DCR-DVD103 Outer Cover Replacement: adım 9, 1 resimden 1.
    • Gently pull apart the outer silver case and screen.
    • Remove the copper wire strip to detach the case from the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
kaitlin
342 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 7-44, Regan Winter 2011 Cal Poly, Team 7-44, Regan Winter 2011 üyesi
CPSU-REGAN-W11S7G44
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 6
Her zaman: 2,471
