Giriş
The LCD Screen is a crucial component to the playback of the camera. The camera will most likely take pictures if the LCD Screen is broken, but will be unable to show the pictures or setting options through the screen. If you wish to change the resolution settings on the camera, a broken or damaged LCD Screen must be fixed.
Neye ihtiyacın var
Remove the battery.
Use Philips #000 screwdriver to remove the 3mm screw under the battery
2 farklı kişi bu kılavuzu tamamladı.
