Ana içeriğe geç
Sony Handycam HDR­-CX220 Display Screen Replacement
Neye ihtiyacın var
  1. Sony Handycam HDR­-CX220 Display Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Push in the battery indicator.
  2. Sony Handycam HDR­-CX220 Display Screen Replacement: adım 2, 1 resimden 1.
    • Slide the battery out of the slot.
    • To put the battery back in, line up the battery's metal part with the camera's and slide it in.
  3. Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: adım 3, 3 resimden 1. Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: adım 3, 3 resimden 2. Sony Handycam HDR­-CX220 Display Screen Replacement, Camera's Body: adım 3, 3 resimden 3.
    • Use the Phillips #0 screwdriver to remove the two 5mm screws.
    • Use the Phillips #0 screwdriver to remove the three 5mm screws.
  4. Sony Handycam HDR­-CX220 Display Screen Replacement: adım 4, 3 resimden 1. Sony Handycam HDR­-CX220 Display Screen Replacement: adım 4, 3 resimden 2. Sony Handycam HDR­-CX220 Display Screen Replacement: adım 4, 3 resimden 3.
    • Use the plastic opening tool to loosen the plastic case of the camcorder.
  5. Sony Handycam HDR­-CX220 Display Screen Replacement: adım 5, 1 resimden 1.
    • Use your hands to remove the plastic case.
    • Gently pull on the case not to damage anything internally.
  6. Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: adım 6, 2 resimden 1. Sony Handycam HDR­-CX220 Display Screen Replacement, Display Screen: adım 6, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remover the two (5mm) screws on the outer part and one (3mm) in the middle.
    • In the second image, there is a second screw on the opposite side of the screen hinge. This screw is not shown, but must also be removed.
  7. Sony Handycam HDR­-CX220 Display Screen Replacement: adım 7, 1 resimden 1.
    • Use the plastic opening tool to remove the plastic case protecting the screen
    • Pull it gently not to damage anything under the case
  8. Sony Handycam HDR­-CX220 Display Screen Replacement: adım 8, 2 resimden 1. Sony Handycam HDR­-CX220 Display Screen Replacement: adım 8, 2 resimden 2.
    • Use the Phillips #0 screwdriver to remove the 2 screws shown
    • Use your hands to carefully unhook the screen from the highlighted hook
  9. Sony Handycam HDR­-CX220 Display Screen Replacement: adım 9, 3 resimden 1. Sony Handycam HDR­-CX220 Display Screen Replacement: adım 9, 3 resimden 2. Sony Handycam HDR­-CX220 Display Screen Replacement: adım 9, 3 resimden 3.
    • Use your hands to carefully remove the tape
    • After removing the tape, pull on the wire disconnecting it from the screen.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Keven
811 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 8-5, Botvin Spring 2016 UMass Dartmouth, Team 8-5, Botvin Spring 2016 üyesi
UMASSD-BOTVIN-S16S8G5
3 Üyeler
12 adet Kılavuz yazıldı
3 Yorum
How do you mount hdr cx220 lcd cable flat? can you help me?
Rafael Oliveira - Yanıt
gjhgvnvyh n hygfv
ANM WORLD - Yanıt
We have a camera 220. Whose dipstick display strip has deteriorated again. Where can I find this strip? Video is good information so that's why
ANM WORLD - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 2,536
