Giriş
The replacement of the lens is needed if your videos are not coming out the way you want them to. If you notice that there are dirt or anything unusual on the lens it will ruin every video you take in the future, unless the lens is replaced.
Neye ihtiyacın var
Use the Phillips #0 screwdriver to remove the two 5mm screws.
Use the Phillips #0 screwdriver to remove the three 5mm screws.
Use the Phillips #0 Screwdriver to remove the 5mm screw
Use the Plastic Opening tools to unhook the highlighted area.
2 farklı kişi bu kılavuzu tamamladı.
