Ana içeriğe geç
Sony Handycam HDR-CX380 Battery Replacement
  1. Sony Handycam HDR-CX380 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Rotate your camera such that the underside is facing you and the lens is facing the ground.
    • You should be able to see the camera's label, and it should be rotated 90 degrees counterclockwise.
  2. Sony Handycam HDR-CX380 Battery Replacement: adım 2, 1 resimden 1.
    • Using your left thumb, push down the slider to the left of the SD card slot.
    • When inserting a new battery or reinserting the one you removed, you can ignore this step.
  3. Sony Handycam HDR-CX380 Battery Replacement: adım 3, 2 resimden 1. Sony Handycam HDR-CX380 Battery Replacement: adım 3, 2 resimden 2.
    • Using your right index finger and thumb, pull the battery toward you and then away from the camera.
Sonuç
To insert a new battery or reinsert the one you removed, simply follow step 3 in reverse order and rotate the camera as described in step 1.
Bir başkası bu kılavuzu tamamladı.
John Santoro
729 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-5, Blackwell Winter 2016 USF Tampa, Team 16-5, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S16G5
3 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 12
Her zaman: 582
