Ana içeriğe geç
Sony Handycam HDR-CX380 Camera Shell Replacement
Neye ihtiyacın var
  1. Sony Handycam HDR-CX380 Camera Shell Replacement, Battery: adım 1, 1 resimden 1.
    • Rotate your camera such that the underside is facing you and the lens is facing the ground.
    • You should be able to see the camera's label, and it should be rotated 90 degrees counterclockwise.
  2. Sony Handycam HDR-CX380 Camera Shell Replacement: adım 2, 1 resimden 1.
    • Using your left thumb, push down the slider to the left of the SD card slot.
    • When inserting a new battery or reinserting the one you removed, you can ignore this step.
  3. Sony Handycam HDR-CX380 Camera Shell Replacement: adım 3, 2 resimden 1. Sony Handycam HDR-CX380 Camera Shell Replacement: adım 3, 2 resimden 2.
    • Using your right index finger and thumb, pull the battery toward you and then away from the camera.
  4. Sony Handycam HDR-CX380 Camera Shell Replacement, Camera Shell: adım 4, 1 resimden 1.
    • Orient the camera with the battery side facing up.
  5. Sony Handycam HDR-CX380 Camera Shell Replacement: adım 5, 1 resimden 1.
    • Remove the single 4.5 mm Phillips #00 screw.
    • Remove the single 5.5 mm Phillips #00 screw.
  6. Sony Handycam HDR-CX380 Camera Shell Replacement: adım 6, 2 resimden 1. Sony Handycam HDR-CX380 Camera Shell Replacement: adım 6, 2 resimden 2.
    • With the blue plastic opening tools, gently pry the plastic casing surrounding the start/stop button free.
    • Remove the casing using your right thumb and index finger.
  7. Sony Handycam HDR-CX380 Camera Shell Replacement: adım 7, 1 resimden 1.
    • Flip open the LCD panel to get to the side panel.
    • Remove the three 5.5 mm Phillips #00 screws.
  8. Sony Handycam HDR-CX380 Camera Shell Replacement: adım 8, 1 resimden 1.
    • Turn the camera around to the grip side and remove the 5.5 mm Phillips Head screw using your J00 Phillips Head screwdriver.
  9. Sony Handycam HDR-CX380 Camera Shell Replacement: adım 9, 1 resimden 1.
    • With the bottom of the camera facing up, remove the two 5.5mm Phillips #00 screws.
  10. Sony Handycam HDR-CX380 Camera Shell Replacement: adım 10, 2 resimden 1. Sony Handycam HDR-CX380 Camera Shell Replacement: adım 10, 2 resimden 2.
    • Orient the camera so the bottom is facing you.
    • Use the blue plastic opening tools to gently ease the camera shell off of the camera.
    • Rotate the camera so the LCD side panel is facing you and gently pry the shell off from the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zackary Williams
457 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-5, Blackwell Winter 2016 USF Tampa, Team 16-5, Blackwell Winter 2016 üyesi
USFT-BLACKWELL-W16S16G5
3 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 309
