Giriş
In this guide, you will learn how to remove the shutter assembly from the Sony Handycam HDR-CX380. Completely removing the shutter assembly must be done with caution, as it is connected to the motherboard with sensitive electrical ribbon.
Neye ihtiyacın var
Rotate your camera such that the underside is facing you and the lens is facing the ground.
Orient the camera such that the lens is facing to your left.
Using your right hand to hold the camera, gently remove the lens panel from the camera with your left hand.
Rotate the camera so that it is upright and the lens is pointed to your left.
Using your right hand to hold the screwdriver and your left to hold the camera, remove the single 5.5 mm Phillips #00 screw from on the top of the shutter assembly.
