Giriş
Removing the battery is something that can be done by hand and should only take a few seconds to complete. Be sure to exercise caution when removing the battery as to avoid damaging the camera or harming yourself.
Locate the slider labeled "BATT" and pull it back from the battery with your thumb.
To replace a new battery, simply snap the battery into the slot from which you removed it from.
Bir başkası bu kılavuzu tamamladı.
