Giriş
This guide will help to locate and remove the motherboard for replacement. This will involve removing a significant portion of the camera and wiring.
Neye ihtiyacın var
Locate the slider labeled "BATT" and pull it back from the battery with your thumb.
Use the Phillips #00 head to remove the following 5.5mm screws on the left-hand side.
Use the Phillips #00 head to remove the following 5.5mm screws on the right-hand side near the lens.
To begin removing the metal casing, use the Phillips #00 head to remove the following 5.5mm screws.
Bir başkası bu kılavuzu tamamladı.
