Ana içeriğe geç
Sony Handycam HDR-CX675 Shutter Assembly Replacement
Neye ihtiyacın var
  1. Sony Handycam HDR-CX675 Shutter Assembly Replacement, Camera Shell: adım 1, 1 resimden 1.
    • The battery should be removed and oriented upwards.
  2. Sony Handycam HDR-CX675 Shutter Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the side 4.5 mm JIS #00 screw using JIS Screwdriver
    • Remove the 5.5 mm JIS #00 screw.
  3. Sony Handycam HDR-CX675 Shutter Assembly Replacement: adım 3, 2 resimden 1. Sony Handycam HDR-CX675 Shutter Assembly Replacement: adım 3, 2 resimden 2.
    • Gently pry the plastic case surrounding the start/stop button free by using the blue plastic opening tools.
    • Remove the casing using your thumb and index finger.
  4. Sony Handycam HDR-CX675 Shutter Assembly Replacement: adım 4, 1 resimden 1.
    • Turn the camera around and flip open the LCD screen to expose the side panel.
    • Remove the 5.5mm #00 screw using the J00 head screwdriver.
  5. Sony Handycam HDR-CX675 Shutter Assembly Replacement: adım 5, 1 resimden 1.
    • Turn the camera to the handgrip side and unscrew two of the 5.5mm JIS #00 head screws using the JIS #00 head screwdriver.
  6. Sony Handycam HDR-CX675 Shutter Assembly Replacement: adım 6, 1 resimden 1.
    • Remove the two 5.5mm JIS #00 screws with the bottom of the camera facing up.
  7. Sony Handycam HDR-CX675 Shutter Assembly Replacement: adım 7, 1 resimden 1.
    • Turn the camera around in a way that the bottom of the camera is facing you.
    • Use the blue opening tool to gently remove the camera shell off of the camera.
  8. Sony Handycam HDR-CX675 Shutter Assembly Replacement, Lens Cover Panel: adım 8, 1 resimden 1.
    • Using the blue plastic opener smoothly to take the camera shell off.
  9. Sony Handycam HDR-CX675 Shutter Assembly Replacement: adım 9, 2 resimden 1. Sony Handycam HDR-CX675 Shutter Assembly Replacement: adım 9, 2 resimden 2.
    • Let the lens of the camera be pointed to your left.
    • Keep holding the camera with your right hand then gently remove the lens cover panel with your left hand.
  10. Sony Handycam HDR-CX675 Shutter Assembly Replacement, Shutter Assembly: adım 10, 1 resimden 1.
    • Place the camera on its lens and keep the LCD screen open and pointed to your right.
    • Remove the 5.5mm JIS #00 screws from the hinge of the camera.
  11. Sony Handycam HDR-CX675 Shutter Assembly Replacement: adım 11, 2 resimden 1. Sony Handycam HDR-CX675 Shutter Assembly Replacement: adım 11, 2 resimden 2.
    • Hold the camera with your left hand, and gently remove the shutter assembly part.
  12. Sony Handycam HDR-CX675 Shutter Assembly Replacement: adım 12, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Hold the camera that the bottom is upwards and lens pointed to your left hand.
    • By the metal tweezers, remove the white wire that is connecting the shutter assembly and motherboard
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mohamed Nazer
403 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-2, Eyestone Spring 2017 USF Tampa, Team 8-2, Eyestone Spring 2017 üyesi
USFT-EYESTONE-S17S8G2
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 12
Son 30 gün: 33
Her zaman: 877
