Ana içeriğe geç
Sony ICF-C1T Tuner Dial Replacement
Neye ihtiyacın var
    1. Sony ICF-C1T Tuner Dial Replacement, Tuner Dial: adım 1, 1 resimden 1.
      • Using the Phillips #00 screwdriver, remove four 14mm screws from the underside of the device.
      • Make sure that the clock is unplugged and the battery is removed before tampering with the device to avoid electrical shock.
      FixBot'a Sor
      Yorum Ekle
    2. Sony ICF-C1T Tuner Dial Replacement: adım 2, 1 resimden 1.
      • Use the opening tool to pry apart the edges of the top and side portions of the device.
      FixBot'a Sor
      Yorum Ekle
    3. Sony ICF-C1T Tuner Dial Replacement: adım 3, 2 resimden 1. Sony ICF-C1T Tuner Dial Replacement: adım 3, 2 resimden 2.
      • Separate the device by gently pulling up on the top portion.
      • Use caution when pulling the device apart as the clock display is located close to the front face plate and is connected by multiple wires.
      FixBot'a Sor
      Yorum Ekle
    4. Sony ICF-C1T Tuner Dial Replacement: adım 4, 2 resimden 1. Sony ICF-C1T Tuner Dial Replacement: adım 4, 2 resimden 2.
      • To remove the motherboard, gently pull apart the sides of the device.
      • Do not pull hard on the motherboard, because it is still connected by multiple wires inside the device.
      • Be careful of sharp pieces on the motherboard.
      • Having help for this step might make things quicker and easier.
      FixBot'a Sor
      Yorum Ekle
    5. Sony ICF-C1T Tuner Dial Replacement: adım 5, 3 resimden 1. Sony ICF-C1T Tuner Dial Replacement: adım 5, 3 resimden 2. Sony ICF-C1T Tuner Dial Replacement: adım 5, 3 resimden 3.
      • Remove the tuner dial by pulling it off of the motherboard. This can take a little force to remove.
      FixBot'a Sor
      Yorum Ekle
Sonuç
1Rehber Yorum
Thanks, this was not fun but the guide helped.
Campbell Kerr - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 43
Her zaman: 2,501
