Ana içeriğe geç
Sony ICF-C1iPMK2 Speaker Replacement
Neye ihtiyacın var
  1. Sony ICF-C1iPMK2 Speaker Replacement, Speaker: adım 1, 2 resimden 1. Sony ICF-C1iPMK2 Speaker Replacement, Speaker: adım 1, 2 resimden 2.
    • Unscrew the 1 cm Phillips #00 screws.
    • Use spudger to loosen the back panel of the device.
  2. Sony ICF-C1iPMK2 Speaker Replacement: adım 2, 3 resimden 1. Sony ICF-C1iPMK2 Speaker Replacement: adım 2, 3 resimden 2. Sony ICF-C1iPMK2 Speaker Replacement: adım 2, 3 resimden 3.
    • This step contains ribbon cables. Be careful to not bend or rip these fragile cables, to protect your device.
    • Slowly pull the back panel off until it separated from the main panel.
    • Carefully unplug all of the ribbon cables connecting the back panel to the main panel.
  3. Sony ICF-C1iPMK2 Speaker Replacement: adım 3, 3 resimden 1. Sony ICF-C1iPMK2 Speaker Replacement: adım 3, 3 resimden 2. Sony ICF-C1iPMK2 Speaker Replacement: adım 3, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the power connector with a pair of ESD safe tweezers.
    • Remove the Aux port connector with a pair of ESD safe tweezers.
    • Slide the button panels out of the chassis.
  4. Sony ICF-C1iPMK2 Speaker Replacement: adım 4, 3 resimden 1. Sony ICF-C1iPMK2 Speaker Replacement: adım 4, 3 resimden 2. Sony ICF-C1iPMK2 Speaker Replacement: adım 4, 3 resimden 3.
    • Unscrew the four 1 cm Phillips #00 screws and remove the speaker cover.
    • Unscrew the 1 cm Phillips #00 screws holding the speaker in place.
    • Remove the old speaker and insert the new one.
Sonuç
KyndleGabel
530 İtibar
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 75
