Giriş
Here is a Sony TV that turned on and off every few seconds. To remedy this, replace the lamp. This is straight forward and only requires a small Allen wrench. As with all work on all electric or electronic equipment, make sure that it is unplugged first.
Neye ihtiyacın var
With both thumb screws removed, the front bezel can now be easily pulled off. It is only held in place by three magnets.
With the bezel out of the way, there will be a small cover held in place by a crossbar and a thumb screw. Loosen the thumb screw and fold the bar out of the way.
The back of the lamp housing is now visible.
13 farklı kişi bu kılavuzu tamamladı.
17Kılavuz Yorumları
Where did you purchase this bulb for $32?
Mine worked 4 3 hours then stayed off.
A y solutions
Thanks a lot. You saved me money
