Ana içeriğe geç
Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement
Neye ihtiyacın var
  1. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement, Swivel: adım 1, 1 resimden 1.
    • Begin by laying the headphones down flat with the speakers facing up.
    • Be sure to unplug the headphones from any other devices.
  2. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: adım 2, 2 resimden 1. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: adım 2, 2 resimden 2.
    • Next, take out the screws that hold the front plate, using a J00 screwdriver.
    • Repeat for both the left and right screws.
    • These screws are very small. It is helpful to have a spot prepared to put the screws to avoid losing pieces.
  3. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: adım 3, 1 resimden 1.
    • Now that the screws have been removed, pull away the plastic casing that covers the swivel piece (directly above the speaker).
  4. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: adım 4, 1 resimden 1.
    • Now that the swivel piece is exposed, use a J00 screwdriver to unscrew the center screw.
    • Repeat this process on both sides if necessary.
    • This center screw is the piece that retains the swivel action, unscrew completely and remove to replace.
  5. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement, Swivel Plastic Cover: adım 5, 1 resimden 1.
    • With the swivel screw removed, remove the plastic casing.
  6. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: adım 6, 1 resimden 1.
    • Using a little amount of force, slide the plastic cover off of the headband.
  7. Sony MDR-XB450AP Extra Bass Headphones Swivel Plastic Cover Replacement: adım 7, 1 resimden 1.
    • Pull the plastic until the cover is fully removed.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bir Yorum
Necesito la pieza, dónde la compro?
lucas2188 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 3,225
