Ana içeriğe geç
Sony NEX-5R Main Navigation Button Replacement
Neye ihtiyacın var
  1. Sony NEX-5R Main Navigation Button Replacement, Rear Case: adım 1, 1 resimden 1.
    • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
  2. Sony NEX-5R Main Navigation Button Replacement: adım 2, 1 resimden 1.
    • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
  3. Sony NEX-5R Main Navigation Button Replacement: adım 3, 1 resimden 1.
    • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
  4. Sony NEX-5R Main Navigation Button Replacement: adım 4, 1 resimden 1.
    • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
  5. Sony NEX-5R Main Navigation Button Replacement: adım 5, 2 resimden 1. Sony NEX-5R Main Navigation Button Replacement: adım 5, 2 resimden 2.
    • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
    • The back frame is fragile, so use the spudger gently.
  6. Sony NEX-5R Main Navigation Button Replacement: adım 6, 1 resimden 1.
    • The back case should now be removed and look like this.
  7. Sony NEX-5R Main Navigation Button Replacement, Main Navigation Button: adım 7, 1 resimden 1.
    • Use spudger to pull the lead out from its housing.
  8. Sony NEX-5R Main Navigation Button Replacement: adım 8, 2 resimden 1. Sony NEX-5R Main Navigation Button Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Squeeze the lead with the tweezers and hold the lead teeth tightly with your fingers. Pull straight out to disconnect.
  9. Sony NEX-5R Main Navigation Button Replacement: adım 9, 2 resimden 1. Sony NEX-5R Main Navigation Button Replacement: adım 9, 2 resimden 2.
    • The navigation button component should now be separate and able to be replaced with new component. The camera and navigation button should appear as shown.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Emily Trujillo
1.153 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-9, Regan Spring 2014 Cal Poly, Team 8-9, Regan Spring 2014 üyesi
CPSU-REGAN-S14S8G9
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 35
Her zaman: 4,611
