Ana içeriğe geç
Sony NEX-5R Motherboard Replacement
Neye ihtiyacın var
    1. Sony NEX-5R Motherboard Replacement, Front Case: adım 1, 2 resimden 1. Sony NEX-5R Motherboard Replacement, Front Case: adım 1, 2 resimden 2.
      • Open the battery pack door by moving the slider to "OPEN".
      • Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Sony NEX-5R Motherboard Replacement: adım 2, 1 resimden 1.
      • Remove the 3.25 mm exterior screw with a Phillips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. Sony NEX-5R Motherboard Replacement: adım 3, 2 resimden 1. Sony NEX-5R Motherboard Replacement: adım 3, 2 resimden 2.
      • Use the spudger to raise the corner of the case from the camera.
      • One component of the front case should now be separate from the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Sony NEX-5R Motherboard Replacement, Rear Case: adım 4, 1 resimden 1.
      • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. Sony NEX-5R Motherboard Replacement: adım 5, 1 resimden 1.
      • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
      FixBot'a Sor
      Yorum Ekle
    3. Sony NEX-5R Motherboard Replacement: adım 6, 1 resimden 1.
      • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
      FixBot'a Sor
      Yorum Ekle
    4. Sony NEX-5R Motherboard Replacement: adım 7, 1 resimden 1.
      • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
      FixBot'a Sor
      Yorum Ekle
    5. Sony NEX-5R Motherboard Replacement: adım 8, 2 resimden 1. Sony NEX-5R Motherboard Replacement: adım 8, 2 resimden 2.
      • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
      • The back frame is fragile, so use the spudger gently.
      FixBot'a Sor
      Yorum Ekle
    6. Sony NEX-5R Motherboard Replacement: adım 9, 1 resimden 1.
      • The back case should now be removed and look like this.
      FixBot'a Sor
      Yorum Ekle
    1. Sony NEX-5R Motherboard Replacement, Motherboard: adım 10, 1 resimden 1.
      • Remove the two copper 2.25mm phillips head screws from the bottom of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Sony NEX-5R Motherboard Replacement: adım 11, 1 resimden 1.
      • Remove the copper 2.25mm phillips head screw from the side of the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Sony NEX-5R Motherboard Replacement: adım 12, 3 resimden 1. Sony NEX-5R Motherboard Replacement: adım 12, 3 resimden 2. Sony NEX-5R Motherboard Replacement: adım 12, 3 resimden 3.
      • Use the spudger tool to unhook the neck strap anchor from the side of the camera with the navigation buttons.
      FixBot'a Sor
      Yorum Ekle
    4. Sony NEX-5R Motherboard Replacement: adım 13, 1 resimden 1.
      • Remove the six copper 2.25mm phillips head screws from the top of the motherboard assembly on the camera
      FixBot'a Sor
      Yorum Ekle
    5. Sony NEX-5R Motherboard Replacement: adım 14, 1 resimden 1.
      • Flip the main navigation button up behind the camera to further expose the frame
      FixBot'a Sor
      Yorum Ekle
    6. Sony NEX-5R Motherboard Replacement: adım 15, 1 resimden 1.
      • Lift the LCD screen straight up and off of the camera. The motherboard frame is attached and the assembly will easily separate from the camera.
      • The lead connecting the LCD screen and the motherboard is fragile. Be careful not to damage the wiring or either end of the leads.
      FixBot'a Sor
      Yorum Ekle
    7. Sony NEX-5R Motherboard Replacement: adım 16, 2 resimden 1. Sony NEX-5R Motherboard Replacement: adım 16, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Remove the lead connecting the LCD screen and frame assembly to the motherboard. Using tweezers, pull straight out from the lead to disconnect
      • Always work carefully when removing internal leads. These wires and ribbons are fragile.
      • The LCD screen and frame should now be separate from the main camera and appear as shown in the image
      FixBot'a Sor
      Yorum Ekle
    8. Sony NEX-5R Motherboard Replacement: adım 17, 1 resimden 1.
      • Remove the small wire lead from the motherboard using the tweezers. Firmly grasp the lead wire near the connection and pull up from the motherboard at an angle. The lead will snap off of the mount.
      FixBot'a Sor
      Yorum Ekle
    9. Sony NEX-5R Motherboard Replacement: adım 18, 1 resimden 1.
      • On the top left corner of the motherboard, unhook the black grommet from the housing by pinching the small tab with the tweezers and lifting up.
      FixBot'a Sor
      Yorum Ekle
    10. Sony NEX-5R Motherboard Replacement: adım 19, 3 resimden 1. Sony NEX-5R Motherboard Replacement: adım 19, 3 resimden 2. Sony NEX-5R Motherboard Replacement: adım 19, 3 resimden 3.
      • On the top left side of the motherboard, remove the first lead from housing using the tweezers. Firmly grasp the lead with tweezers and pull straight out from the housing.
      FixBot'a Sor
      Yorum Ekle
    11. Sony NEX-5R Motherboard Replacement: adım 20, 1 resimden 1.
      • Next, remove the first lead on the right side of the motherboard. Using tweezers, tightly grasp the lead and pull straight out from the housing.
      FixBot'a Sor
      Yorum Ekle
    12. Sony NEX-5R Motherboard Replacement: adım 21, 1 resimden 1.
      • Remove the next lead on the side of the motherboard. For this lead, you may have to grasp it on either side with the tweezers as shown due to the lack of room beneath the lead. When securely grasped, pull straight out of the housing to remove the lead.
      FixBot'a Sor
      Yorum Ekle
    13. Sony NEX-5R Motherboard Replacement: adım 22, 1 resimden 1.
      • Remove the final lead on the opposite side of the motherboard with tweezers. Tightly hold and the lead on either side and pull straight out of the housing to disconnect.
      FixBot'a Sor
      Yorum Ekle
    14. Sony NEX-5R Motherboard Replacement: adım 23, 1 resimden 1.
      • On the lower side of the motherboard, you must remove the small metal frame that covers the socket-lead. Pinch the frame on each side with the tweezers and lift up to easily remove it.
      FixBot'a Sor
      Yorum Ekle
    15. Sony NEX-5R Motherboard Replacement: adım 24, 1 resimden 1.
      • Pinch the cylindrical socket lead on each side with tweezers and lift out from its housing to remove the socket-lead.
      FixBot'a Sor
      Yorum Ekle
    16. Sony NEX-5R Motherboard Replacement: adım 25, 3 resimden 1. Sony NEX-5R Motherboard Replacement: adım 25, 3 resimden 2. Sony NEX-5R Motherboard Replacement: adım 25, 3 resimden 3.
      • With all secondary leads removed, lift the motherboard away from the camera to expose the primary lead underneath. While holding the motherboard lightly in one hand, tightly pinch the primary lead near the housing with the tweezers. Pull the lead straight out from the housing to completely separate the motherboard from the camera.
      • The removed motherboard and camera body should now appear as shown.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Emily Trujillo
1.153 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-9, Regan Spring 2014 Cal Poly, Team 8-9, Regan Spring 2014 üyesi
CPSU-REGAN-S14S8G9
4 Üyeler
14 adet Kılavuz yazıldı
3Kılavuz Yorumları
I have a Sony NEX-6 mirrorless...Is the process essentially the same?
Emily - Yanıt Paylaş
My sony nex c have a problem every time i ‘m opened it with a message of “camera error”. May i know what is the major problem of this?
Norulhuda Azharruddin - Yanıt Paylaş
One of the common failing part of this model
is the memory card board which is quite difficult to replace. This model requires a guide for that.
Harbert Wolfstein - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 66
Her zaman: 9,373
