Giriş
The removal of the motherboard involves removing a significant portion of the rear casing, the internal casing, and the removal of component connections. Care and safe handling is advised in this guide.
Neye ihtiyacın var
Open the battery pack door by moving the slider to "OPEN".
Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
Remove the two copper 2.25mm phillips head screws from the bottom of the camera.
Bu adımda kullanılan alet:Tweezers$4.99
Remove the lead connecting the LCD screen and frame assembly to the motherboard. Using tweezers, pull straight out from the lead to disconnect
The LCD screen and frame should now be separate from the main camera and appear as shown in the image
With all secondary leads removed, lift the motherboard away from the camera to expose the primary lead underneath. While holding the motherboard lightly in one hand, tightly pinch the primary lead near the housing with the tweezers. Pull the lead straight out from the housing to completely separate the motherboard from the camera.
The removed motherboard and camera body should now appear as shown.
6 farklı kişi bu kılavuzu tamamladı.
3Kılavuz Yorumları
My sony nex c have a problem every time i ‘m opened it with a message of “camera error”. May i know what is the major problem of this?
One of the common failing part of this model
is the memory card board which is quite difficult to replace. This model requires a guide for that.
