Ana içeriğe geç
Sony NEX-5R Rear Case Replacement
Neye ihtiyacın var
  1. Sony NEX-5R Rear Case Replacement, Front Case: adım 1, 2 resimden 1. Sony NEX-5R Rear Case Replacement, Front Case: adım 1, 2 resimden 2.
    • Open the battery pack door by moving the slider to "OPEN".
    • Remove the 3.25 mm silver screw inside the battery pack with a Phillips screwdriver.
  2. Sony NEX-5R Rear Case Replacement: adım 2, 1 resimden 1.
    • Remove the 3.25 mm exterior screw with a Phillips screwdriver.
  3. Sony NEX-5R Rear Case Replacement: adım 3, 2 resimden 1. Sony NEX-5R Rear Case Replacement: adım 3, 2 resimden 2.
    • Use the spudger to raise the corner of the case from the camera.
    • One component of the front case should now be separate from the camera.
  4. Sony NEX-5R Rear Case Replacement, Rear Case: adım 4, 1 resimden 1.
    • Remove the three (3.5 mm) screws from the bottom of the camera with the Phillips screwdriver.
  5. Sony NEX-5R Rear Case Replacement: adım 5, 1 resimden 1.
    • Open the HDMI port, and remove the the two (3.5 mm) Phillips screws exposed on that side.
  6. Sony NEX-5R Rear Case Replacement: adım 6, 1 resimden 1.
    • Remove the two 4mm screws from the interior of the battery pack, and one 3.5mm screw from beside it.
  7. Sony NEX-5R Rear Case Replacement: adım 7, 1 resimden 1.
    • Looking at the bottom of the camera, use the spudger to lift the rear case away from the camera body.
  8. Sony NEX-5R Rear Case Replacement: adım 8, 2 resimden 1. Sony NEX-5R Rear Case Replacement: adım 8, 2 resimden 2.
    • Using the spudger again, carefully pry from the top of the camera to remove the back frame.
    • The back frame is fragile, so use the spudger gently.
  9. Sony NEX-5R Rear Case Replacement: adım 9, 1 resimden 1.
    • The back case should now be removed and look like this.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Emily Trujillo
1.114 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-9, Regan Spring 2014 Cal Poly, Team 8-9, Regan Spring 2014 üyesi
CPSU-REGAN-S14S8G9
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 25
Her zaman: 2,761
