Ana içeriğe geç
Sony NEX-7 Battery Replacement
  1. Sony NEX-7 Battery Replacement, Battery: adım 1, 2 resimden 1. Sony NEX-7 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
    • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
  2. Sony NEX-7 Battery Replacement: adım 2, 1 resimden 1.
    • Flip the camera over such that the power switch points down.
    • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
  3. Sony NEX-7 Battery Replacement: adım 3, 1 resimden 1.
    • With the battery door open, push the blue lever in the battery compartment to release the battery.
Sonuç
To replace the battery, fit it in the slot, then close and lock the door.
2 farklı kişi bu kılavuzu tamamladı.
Tyler
578 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 10-55, Amido Spring 2014 Cal Poly, Team 10-55, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S10G55
4 Üyeler
36 adet Kılavuz yazıldı
Bir Yorum
I’ve done this about a million times. :)
Martin Hurley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 20
Her zaman: 2,257
