Ana içeriğe geç
Sony NEX-7 Lens Mount Replacement
Neye ihtiyacın var
  1. Sony NEX-7 Lens Mount Replacement, Battery: adım 1, 2 resimden 1. Sony NEX-7 Lens Mount Replacement, Battery: adım 1, 2 resimden 2.
    • We need to turn off the camera because we are removing components that could get damaged if the power is still on.
    • If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
  2. Sony NEX-7 Lens Mount Replacement: adım 2, 1 resimden 1.
    • Flip the camera over such that the power switch points down.
    • Slide the switch on the bottom of the camera grip towards the lens to open the battery door.
  3. Sony NEX-7 Lens Mount Replacement: adım 3, 1 resimden 1.
    • With the battery door open, push the blue lever in the battery compartment to release the battery.
  4. Sony NEX-7 Lens Mount Replacement, SD card: adım 4, 1 resimden 1.
    • To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
    • Pull the card out with your fingers.
  5. Sony NEX-7 Lens Mount Replacement, Lens: adım 5, 2 resimden 1. Sony NEX-7 Lens Mount Replacement, Lens: adım 5, 2 resimden 2.
    • First, turn the camera upside down.
    • Press the button located next to silver lens mount and rotate the lens counterclockwise.
    • Pull the lens away from the camera body.
    • After removing the lens, replace the lens or attach the body cap as soon as possible to prevent damage to the shutter.
  6. Sony NEX-7 Lens Mount Replacement, Lens Mount: adım 6, 1 resimden 1.
    • With the front of the camera facing you, remove the four silver #00 Phillips screws from the metal lens mount.
  7. Sony NEX-7 Lens Mount Replacement: adım 7, 1 resimden 1.
    • Remove these three layers from the lens mount with your finger or by turning the camera face down.
  8. Sony NEX-7 Lens Mount Replacement: adım 8, 1 resimden 1.
    • Remove the two newly visible #00 screws within the metal ring.
  9. Sony NEX-7 Lens Mount Replacement: adım 9, 1 resimden 1.
    • Remove the final metal ring from the mount.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Jay Miley
5.230 İtibar
13 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 10-55, Amido Spring 2014 Cal Poly, Team 10-55, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S10G55
4 Üyeler
36 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 9
Son 30 gün: 23
Her zaman: 2,358
