Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
This guide will show you how take out the SD card, which stores pictures and videos.
If the camera is on, rotate the power switch on top of the camera counterclockwise to turn the camera off.
To the left of the battery compartment, the SD card needs to be pushed down slightly with your fingers, which will cause the card to eject.
Pull the card out with your fingers.
To replace the SD card, press the card into the slot until it clicks. It will stay on its own. If it doesn't go in all the way, make sure the gold contacts are down and towards the battery door.
2 farklı kişi bu kılavuzu tamamladı.
