Ana içeriğe geç
Sony NWZ-E473 Screen Replacement
Neye ihtiyacın var
  1. Sony NWZ-E473  Screen Replacement, Back Panel: adım 1, 1 resimden 1.
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Sony NWZ-E473  Screen Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to loosen the bottom portion of device.
    FixBot'a Sor
    Yorum Ekle
  3. Sony NWZ-E473  Screen Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool to loosen the top panel of the device.
    FixBot'a Sor
    Yorum Ekle
  4. Sony NWZ-E473  Screen Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
    FixBot'a Sor
    Yorum Ekle
  5. Sony NWZ-E473  Screen Replacement: adım 5, 3 resimden 1. Sony NWZ-E473  Screen Replacement: adım 5, 3 resimden 2. Sony NWZ-E473  Screen Replacement: adım 5, 3 resimden 3.
    • Remove the back plate from the device.
    FixBot'a Sor
    Yorum Ekle
  6. Sony NWZ-E473  Screen Replacement, Screen: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a nylon spudger or tweezers to remove the plastic USB cover.
    FixBot'a Sor
    Yorum Ekle
  7. Sony NWZ-E473  Screen Replacement: adım 7, 1 resimden 1.
    • Use a Phillips #00 screwdriver to unscrew two 2 mm screws located on the top corners of the device.
    FixBot'a Sor
    Yorum Ekle
  8. Sony NWZ-E473  Screen Replacement: adım 8, 1 resimden 1.
    • Use a nylon spudger or tweezers to remove the plastic protective plate at the top of device.
    FixBot'a Sor
    Yorum Ekle
  9. Sony NWZ-E473  Screen Replacement: adım 9, 2 resimden 1. Sony NWZ-E473  Screen Replacement: adım 9, 2 resimden 2.
    • Remove the plastic protective frame located over the motherboard with tweezers and a spudger.
    FixBot'a Sor
    Yorum Ekle
  10. Sony NWZ-E473  Screen Replacement: adım 10, 1 resimden 1.
    • Remove screen connection from motherboard using tweezers and spudger.
    FixBot'a Sor
    Yorum Ekle
  11. Sony NWZ-E473  Screen Replacement: adım 11, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove two 3 mm screws at the bottom sides and two 1 mm screws at top sides of the device.
    FixBot'a Sor
    Yorum Ekle
  12. Sony NWZ-E473  Screen Replacement: adım 12, 2 resimden 1. Sony NWZ-E473  Screen Replacement: adım 12, 2 resimden 2.
    • Use a Phillips #00 screwdriver to unscrew two 2 mm screws, and remove the motherboard from the device with tweezers and a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  13. Sony NWZ-E473  Screen Replacement: adım 13, 2 resimden 1. Sony NWZ-E473  Screen Replacement: adım 13, 2 resimden 2.
    • Disconnect the metal shielding plate from the front panel with tweezers or a plastic opening tool.
    FixBot'a Sor
    Yorum Ekle
  14. Sony NWZ-E473  Screen Replacement: adım 14, 2 resimden 1. Sony NWZ-E473  Screen Replacement: adım 14, 2 resimden 2.
    • Use a plastic opening tool to remove the screen from metal back plate.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Matthew Hintz
330 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 17-6, Watkins Winter 2015 USF Tampa, Team 17-6, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S17G6
4 Üyeler
7 adet Kılavuz yazıldı
1Rehber Yorum
very helpful!!! thx
Stefan Taubert - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 13
Son 30 gün: 34
Her zaman: 1,314
