Ana içeriğe geç
Sony NWZ-E473 Audio Jack Replacement
Neye ihtiyacın var
  1. Sony NWZ-E473 Audio Jack Replacement, Back Panel: adım 1, 1 resimden 1.
    • Use a Phillips #00 screwdriver to unscrew the two 5 mm screws located on the bottom of the back of the device.
  2. Sony NWZ-E473 Audio Jack Replacement: adım 2, 1 resimden 1.
    • Use a plastic opening tool to loosen the bottom portion of device.
  3. Sony NWZ-E473 Audio Jack Replacement: adım 3, 1 resimden 1.
    • Use a plastic opening tool to loosen the top panel of the device.
  4. Sony NWZ-E473 Audio Jack Replacement: adım 4, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the two 3 mm screws located on the portion under the top panel of the device.
  5. Sony NWZ-E473 Audio Jack Replacement: adım 5, 3 resimden 1. Sony NWZ-E473 Audio Jack Replacement: adım 5, 3 resimden 2. Sony NWZ-E473 Audio Jack Replacement: adım 5, 3 resimden 3.
    • Remove the back plate from the device.
  6. Sony NWZ-E473 Audio Jack Replacement, Audio Jack: adım 6, 1 resimden 1.
    • Unscrew one 2.5 mm screw using a Phillips #00 screwdriver on bottom right portion of device located near audio jack.
  7. Sony NWZ-E473 Audio Jack Replacement: adım 7, 2 resimden 1. Sony NWZ-E473 Audio Jack Replacement: adım 7, 2 resimden 2.
    • Disconnect the headphone jack connection from the motherboard using any tool to remove black audio piece that needs to be replaced.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chaz
119 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 17-6, Watkins Winter 2015 USF Tampa, Team 17-6, Watkins Winter 2015 üyesi
USFT-WATKINS-W15S17G6
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 1,028
