Ana içeriğe geç
Sony PlayStation 3D Display Control Buttons Replacement
Neye ihtiyacın var
  1. Sony PlayStation 3D Display Control Buttons Replacement, Rear Case: adım 1, 2 resimden 1. Sony PlayStation 3D Display Control Buttons Replacement, Rear Case: adım 1, 2 resimden 2.
    • Remove the base by pushing in the button and sliding out the unit.
    FixBot'a Sor
    Yorum Ekle
  2. Sony PlayStation 3D Display Control Buttons Replacement: adım 2, 3 resimden 1. Sony PlayStation 3D Display Control Buttons Replacement: adım 2, 3 resimden 2. Sony PlayStation 3D Display Control Buttons Replacement: adım 2, 3 resimden 3.
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
    FixBot'a Sor
    Yorum Ekle
  3. Sony PlayStation 3D Display Control Buttons Replacement: adım 3, 2 resimden 1. Sony PlayStation 3D Display Control Buttons Replacement: adım 3, 2 resimden 2.
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
    FixBot'a Sor
    Yorum Ekle
  4. Sony PlayStation 3D Display Control Buttons Replacement: adım 4, 3 resimden 1. Sony PlayStation 3D Display Control Buttons Replacement: adım 4, 3 resimden 2. Sony PlayStation 3D Display Control Buttons Replacement: adım 4, 3 resimden 3.
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
    FixBot'a Sor
    Yorum Ekle
  5. Sony PlayStation 3D Display Control Buttons Replacement, Control Buttons: adım 5, 1 resimden 1.
    • With the Phillips #01 screwdriver, remove the two 5 mm length x 7 mm head screws from the top and bottom of the control button bar.
    FixBot'a Sor
    Yorum Ekle
  6. Sony PlayStation 3D Display Control Buttons Replacement: adım 6, 2 resimden 1. Sony PlayStation 3D Display Control Buttons Replacement: adım 6, 2 resimden 2.
    • Detach the control button bar by depressing the small white tab that connects the bar to its wires.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tia McNaughton
379 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-16, Maness Fall 2015 Cal Poly, Team 12-16, Maness Fall 2015 üyesi
CPSU-MANESS-F15S12G16
4 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 30
Her zaman: 978
