Ana içeriğe geç
Sony PlayStation 3D Display Power Port Replacement
Neye ihtiyacın var
  1. Sony PlayStation 3D Display Power Port Replacement, Rear Case: adım 1, 2 resimden 1. Sony PlayStation 3D Display Power Port Replacement, Rear Case: adım 1, 2 resimden 2.
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display Power Port Replacement: adım 2, 3 resimden 1. Sony PlayStation 3D Display Power Port Replacement: adım 2, 3 resimden 2. Sony PlayStation 3D Display Power Port Replacement: adım 2, 3 resimden 3.
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display Power Port Replacement: adım 3, 2 resimden 1. Sony PlayStation 3D Display Power Port Replacement: adım 3, 2 resimden 2.
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display Power Port Replacement: adım 4, 3 resimden 1. Sony PlayStation 3D Display Power Port Replacement: adım 4, 3 resimden 2. Sony PlayStation 3D Display Power Port Replacement: adım 4, 3 resimden 3.
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display Power Port Replacement, Power Port: adım 5, 3 resimden 1. Sony PlayStation 3D Display Power Port Replacement, Power Port: adım 5, 3 resimden 2. Sony PlayStation 3D Display Power Port Replacement, Power Port: adım 5, 3 resimden 3.
    • With the Phillips #02 screwdriver, remove the two 5mm length x 7mm head screws from the left and right side of the power port plate.
  6. Sony PlayStation 3D Display Power Port Replacement: adım 6, 3 resimden 1. Sony PlayStation 3D Display Power Port Replacement: adım 6, 3 resimden 2. Sony PlayStation 3D Display Power Port Replacement: adım 6, 3 resimden 3.
    • Remove the power port by depressing the white tab attached to the wires.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Logan Simon
234 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 12-16, Maness Fall 2015 Cal Poly, Team 12-16, Maness Fall 2015 üyesi
CPSU-MANESS-F15S12G16
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 1,529
