Ana içeriğe geç
Sony PlayStation 3D Display Side Speakers Replacement
Neye ihtiyacın var
  1. Sony PlayStation 3D Display Side Speakers Replacement, Rear Case: adım 1, 2 resimden 1. Sony PlayStation 3D Display Side Speakers Replacement, Rear Case: adım 1, 2 resimden 2.
    • Remove the base by pushing in the button and sliding out the unit.
  2. Sony PlayStation 3D Display Side Speakers Replacement: adım 2, 3 resimden 1. Sony PlayStation 3D Display Side Speakers Replacement: adım 2, 3 resimden 2. Sony PlayStation 3D Display Side Speakers Replacement: adım 2, 3 resimden 3.
    • Remove USB port cover from back plate with a metal spudger.
    • This will prevent the cover from falling under the back plate once it is removed.
  3. Sony PlayStation 3D Display Side Speakers Replacement: adım 3, 2 resimden 1. Sony PlayStation 3D Display Side Speakers Replacement: adım 3, 2 resimden 2.
    • With the Phillips #02 screwdriver, remove the six 6 mm length x 6 mm head screws from the back plate.
    • With the Phillips #02 screwdriver, remove the ten 6 mm length x 8 mm head screws from the back plate.
    • These screws have different threads and need to be kept separate.
  4. Sony PlayStation 3D Display Side Speakers Replacement: adım 4, 3 resimden 1. Sony PlayStation 3D Display Side Speakers Replacement: adım 4, 3 resimden 2. Sony PlayStation 3D Display Side Speakers Replacement: adım 4, 3 resimden 3.
    • Remove back plate with a plastic opening tool by slowing prying around the entire plate.
    • Be gentle to avoid breaking the plastic clips which hold the plate.
    • Once separated the plate easily lifts off.
  5. Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: adım 5, 3 resimden 1. Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: adım 5, 3 resimden 2. Sony PlayStation 3D Display Side Speakers Replacement, Side Speakers: adım 5, 3 resimden 3.
    • With the Phillips #01 screwdriver, remove the four 5 mm length x 7 mm head screws from the assembly (two for each side speaker).
  6. Sony PlayStation 3D Display Side Speakers Replacement: adım 6, 3 resimden 1. Sony PlayStation 3D Display Side Speakers Replacement: adım 6, 3 resimden 2. Sony PlayStation 3D Display Side Speakers Replacement: adım 6, 3 resimden 3.
    • Remove the plastic plate covering the speaker.
    • When reassembling, make sure the arrow on the plastic plate is facing up.
    • Lift the speaker out of its holding tray.
  7. Sony PlayStation 3D Display Side Speakers Replacement: adım 7, 2 resimden 1. Sony PlayStation 3D Display Side Speakers Replacement: adım 7, 2 resimden 2.
    • Remove the speaker by depressing the white tab on the speaker wire connector.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
viharim
200 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 12-16, Maness Fall 2015 Cal Poly, Team 12-16, Maness Fall 2015 üyesi
CPSU-MANESS-F15S12G16
4 Üyeler
8 adet Kılavuz yazıldı
Bir Yorum
Speakers in this page are out of stock, do you think these will work? https://www.amazon.com/Speaker-Speakers-...
Ferserk - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 2,522
