Ana içeriğe geç
Sony PlayStation Camera Microphone Array Replacement
Neye ihtiyacın var
    1. Sony PlayStation Camera Microphone Array Replacement, Microphone Array: adım 1, 2 resimden 1. Sony PlayStation Camera Microphone Array Replacement, Microphone Array: adım 1, 2 resimden 2.
      • Separate the camera from the camera stand to gain access to the bottom of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Sony PlayStation Camera Microphone Array Replacement: adım 2, 2 resimden 1. Sony PlayStation Camera Microphone Array Replacement: adım 2, 2 resimden 2.
      • With the PH000 sized screwdriver, remove the two 6.5mm Phillips #000 screws located under the stand connection point, where the cable enters the case.
      FixBot'a Sor
      Yorum Ekle
    3. Sony PlayStation Camera Microphone Array Replacement: adım 3, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Using tweezers, remove the cap holding the cable grommet in place.
      FixBot'a Sor
      Yorum Ekle
    4. Sony PlayStation Camera Microphone Array Replacement: adım 4, 1 resimden 1.
      • Using the tweezers, remove both poly-carbonate lens coverplates.
      • Lift the coverplates slowly, to ensure they do not crack, or break.
      FixBot'a Sor
      Yorum Ekle
    5. Sony PlayStation Camera Microphone Array Replacement: adım 5, 2 resimden 1. Sony PlayStation Camera Microphone Array Replacement: adım 5, 2 resimden 2.
      • Using the PH0 sized screwdriver, remove two 3.2mm Phillips #0 screws, located under the coverplates.
      FixBot'a Sor
      Yorum Ekle
    6. Sony PlayStation Camera Microphone Array Replacement: adım 6, 1 resimden 1.
      • Using extreme care, separate the front of the case, from the back with a metal spudger, or pry tool. The case will scratch easily.
      • The case joints can be hard to spot. They appear as a very fine line in the plastic. Start with light pressure until the seam parts, allowing the pry tool to work.
      FixBot'a Sor
      Yorum Ekle
    7. Sony PlayStation Camera Microphone Array Replacement: adım 7, 2 resimden 1. Sony PlayStation Camera Microphone Array Replacement: adım 7, 2 resimden 2.
      • Using the PH0 sized screwdriver, remove the four 4.5mm Phillips #0 screws securing the circuit assembly to the device housing.
      FixBot'a Sor
      Yorum Ekle
    8. Sony PlayStation Camera Microphone Array Replacement: adım 8, 3 resimden 1. Sony PlayStation Camera Microphone Array Replacement: adım 8, 3 resimden 2. Sony PlayStation Camera Microphone Array Replacement: adım 8, 3 resimden 3.
      • Lift the motherboard and frame from the plastic housing.
      • Disconnect the camera cable from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    9. Sony PlayStation Camera Microphone Array Replacement: adım 9, 2 resimden 1. Sony PlayStation Camera Microphone Array Replacement: adım 9, 2 resimden 2.
      • Using the PH0 sized screwdriver, remove the six 4.2mm Phillips #0 screws securing the motherboard to the metal frame.
      FixBot'a Sor
      Yorum Ekle
    10. Sony PlayStation Camera Microphone Array Replacement: adım 10, 2 resimden 1. Sony PlayStation Camera Microphone Array Replacement: adım 10, 2 resimden 2.
      • Using a plastic opening tool, disconnect the microphone array connector from the motherboard.
      FixBot'a Sor
      Yorum Ekle
    11. Sony PlayStation Camera Microphone Array Replacement: adım 11, 3 resimden 1. Sony PlayStation Camera Microphone Array Replacement: adım 11, 3 resimden 2. Sony PlayStation Camera Microphone Array Replacement: adım 11, 3 resimden 3.
      • Using fine point tweezers, grab hold of each microphone, one at a time, and lift from the plastic frame.
      • Using care to not damage the wires, remove microphone array from the retaining tabs on the plastic frame.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Joshua Gates
268 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-5, Passmore Spring 2017 USF Tampa, Team 5-5, Passmore Spring 2017 üyesi
USFT-PASSMORE-S17S5G5
3 Üyeler
22 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 15
Son 30 gün: 58
Her zaman: 7,825
