Ana içeriğe geç
Neye ihtiyacın var
Bu teardown bir tamir kılavuzu değildir. PlayStation cihazınızı onarmak için, servis kılavuzumuzu kullanın.
  1. Sony PlayStation SCPH-9002 Teardown, Sony PlayStation SCPH-9002 Teardown: adım 1, 2 resimden 1. Sony PlayStation SCPH-9002 Teardown, Sony PlayStation SCPH-9002 Teardown: adım 1, 2 resimden 2.
    • Here's the PS1.
    • Turn the PS1 over and remove the six screws.
    • Note: part number +BV 3X14
  2. Sony PlayStation SCPH-9002 Teardown: adım 2, 1 resimden 1.
    • Remove the top cover. It's very easy.
  3. Sony PlayStation SCPH-9002 Teardown: adım 3, 1 resimden 1.
    • Disconnect both CD-ROM connectors.
    • CD connector one and the socket it connects to.
    • CD connector two and the socket it connects to.
    • Note: part number DEVICE OPTICAL KSM-440AEM
  4. Sony PlayStation SCPH-9002 Teardown: adım 4, 2 resimden 1. Sony PlayStation SCPH-9002 Teardown: adım 4, 2 resimden 2.
    • Remove the CD-ROM reader. You should be able to pull it out gently, although you may have to wiggle it around a bit to loosen the rubber holders.
  5. Sony PlayStation SCPH-9002 Teardown: adım 5, 1 resimden 1.
    • Detach both cables. They go to the power supply and to the memory cards and controller connectors.
  6. Sony PlayStation SCPH-9002 Teardown: adım 6, 1 resimden 1.
    • Remove the four screws and the metal cover.
  7. Sony PlayStation SCPH-9002 Teardown: adım 7, 2 resimden 1. Sony PlayStation SCPH-9002 Teardown: adım 7, 2 resimden 2.
    • Now you have the motherboard!
    • And the power supply.
    • Remove the four screws from the motherboard and the power supply.
  8. Sony PlayStation SCPH-9002 Teardown: adım 8, 1 resimden 1.
    • Once the screws are removed, remove the power supply.
  9. Sony PlayStation SCPH-9002 Teardown: adım 9, 1 resimden 1.
    • Remove the motherboard, and both of the screws from the memory card/ controller connection mechanism.
  10. Sony PlayStation SCPH-9002 Teardown: adım 10, 1 resimden 1.
    • Now, you have all your PlayStation 1 parts!
    • Main Board
    • Lower Casing
    • EMI Shield
    • Power Supply
    • Disk Reader
    • Memory Card/ Controller Mechanism
imacg517
182 İtibar
1 Kılavuz yazıldı
Bir Yorum
That’s a PAL PS1. May be different from NTSC models.
Daniel Powers - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 37
Son 30 gün: 122
Her zaman: 27,947
