Ana içeriğe geç
Sony Playstation 2 SCPH-79002 - Front Cover Replacement
Neye ihtiyacın var
  1. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Flip over your system: adım 1, 1 resimden 1.
    • Flip your machine over to the back.
  2. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Take off the tabs: adım 2, 1 resimden 1.
    • You'll see some outlined grey tabs on the outline of the back, get a spudger or something flat to pop them off.
  3. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Warranty Sticker: adım 3, 1 resimden 1.
    • There is a warranty sticker on the bottom that shows a tab, peeling it off will VOID your warranty.
  4. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Unscrewing: adım 4, 1 resimden 1.
    • When you take off all the tabs, there should be a Phillip Head screw under each tab, unscrew them.
  5. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Taking off the front cover: adım 5, 2 resimden 1. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Taking off the front cover: adım 5, 2 resimden 2.
    • Once you have unscrew them, gently take off the front cover of the Playstation 2.
  6. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Double check you took off the front cover correctly: adım 6, 1 resimden 1.
    • You should now see something like this.
  7. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Get your replacement front cover: adım 7, 1 resimden 1.
    • Get your replacement front cover and prepare to put it back on.
  8. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Clipping: adım 8, 1 resimden 1.
    • Align the front cover and put the front cover firstly on the selected area.
  9. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Clipping: adım 9, 1 resimden 1.
    • Make sure you clip the front cover onto the marked areas.
  10. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Screwing the screws: adım 10, 1 resimden 1.
    • Put the screws in their correct place and screw them into the Playstation 2.
  11. Sony Playstation 2 SCPH-79002 - Front Cover Replacement, Putting the tabs into their right place: adım 11, 1 resimden 1.
    • When done screwing, put the tabs into their correct places.
Sonuç
You have now put a new front cover onto your Playstation 2 superslim!
Bir başkası bu kılavuzu tamamladı.
Zach luc
566 İtibar
4 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 70
Her zaman: 3,751
