Ana içeriğe geç
Sony Pulse Elite Edition Battery Replacement
Neye ihtiyacın var
  1. Sony Pulse Elite Edition Battery Replacement, Identifying Earpiece: adım 1, 1 resimden 1.
    • Locate the left side designation on the headband-earpiece junction.
    • The battery is in the right earpiece.
    • The motherboard is in the left earpiece.
    FixBot'a Sor
    Yorum Ekle
  2. Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: adım 2, 2 resimden 1. Sony Pulse Elite Edition Battery Replacement, Ear Cushion Removal: adım 2, 2 resimden 2.
    • Gently pull around the perimeter of the left ear cushion until it comes off.
    FixBot'a Sor
    Yorum Ekle
  3. Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: adım 3, 2 resimden 1. Sony Pulse Elite Edition Battery Replacement, Outer Ear Rim Removal: adım 3, 2 resimden 2.
    • Use the PH00 Screwdriver to remove the three Phillips 6mm screws around the perimeter of the ear cup.
    • Gently pull the outer ear rim off of the headset assembly.
    • Harsh removal may cause permanent damage to the speaker wires.
    FixBot'a Sor
    Yorum Ekle
  4. Sony Pulse Elite Edition Battery Replacement, Remove Speaker Housing: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using tweezers, gently pry the red and black speaker wires from the attached socket.
    FixBot'a Sor
    Yorum Ekle
  5. Sony Pulse Elite Edition Battery Replacement, Remove Battery: adım 5, 2 resimden 1. Sony Pulse Elite Edition Battery Replacement, Remove Battery: adım 5, 2 resimden 2.
    • Lift up battery and disconnect wires using tweezers.
    • Use a new battery for reconstruction.
    FixBot'a Sor
    Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Chris Echter
871 İtibar
4 adet Kılavuz yazıldı
8Kılavuz Yorumları
Where can I buy the replacement battery for this?
Pretty hard to find...
francisklalumiere - Yanıt Paylaş
Replacement batteries can be found by googling "SP70C battery". It is a Lithium battery with 900mAh and a 3.7v output. AliExpress shows them for $11 including shipping.
David McAndrews - Yanıt Paylaş
Can I mod and replace the battery with a bigger one with no white connection, just positive and negative? Thanks!
marit - Yanıt Paylaş
Thank you so much for this guide. I got a 1000mAh batter from Amazon for 10 dollars. It lasts way longer and was extremely easy to install. Very thankful for this. Thanks!
sharku19z - Yanıt Paylaş
i just attempted... the connector to the battery just pulled off. NOTE: Pull up from PCB not out. The connector sets down into it.
Garrett Parmenter - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 38
Son 30 gün: 171
Her zaman: 14,119
