Ana içeriğe geç
Sony Pulse Elite Edition Headband Replacement
Neye ihtiyacın var
  1. Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: adım 1, 2 resimden 1. Sony Pulse Elite Edition Headband Replacement, Remove Headband Screws: adım 1, 2 resimden 2.
    • Remove the two 5mm Phillips #00 screws from each side of the headband connected to the metal track.
  2. Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: adım 2, 2 resimden 1. Sony Pulse Elite Edition Headband Replacement, Remove Plastic Screw Bracket: adım 2, 2 resimden 2.
    • After removing the screws, push the small plastic protector on one of the sides towards the speaker closest to it.
    • After the protector has slid out of its slot, pull it away from the bar until it pops off the track.
    • Repeat this process for small plastic protector on the other side.
  3. Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: adım 3, 3 resimden 1. Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: adım 3, 3 resimden 2. Sony Pulse Elite Edition Headband Replacement, Rail Cushion Removal: adım 3, 3 resimden 3.
    • Using your thumb, slide the cushion on one of the two adjusting rails toward the closest speaker.
    • Once enough of the cushion has separated from the rail, pull the rest of it off.
    • Repeat the process for the other rail.
  4. Sony Pulse Elite Edition Headband Replacement, Slide Headband Off Rails: adım 4, 1 resimden 1.
    • Gently pull the headband away from one of the speaker component groups, as if expanding it. Continue pulling until it is completely off the track.
    • Remove the white and red wires from inside the headband.
    • Be sure to keep the two speakers close together since they are still linked via the speaker wires.
    • Repeat this process for the other side.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Chris Echter
865 İtibar
4 adet Kılavuz yazıldı
Ekip
Clemson, Team 14-2, Shirley Spring 2015 Clemson, Team 14-2, Shirley Spring 2015 üyesi
CLEM-SHIRLEY-S15S14G2
5 Üyeler
12 adet Kılavuz yazıldı
Bir Yorum
have any experience with the sony gold headset, i got two of them that broke in the same spot, right at the hinge
Rich Gallagher - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 85
Her zaman: 5,881
