Ana içeriğe geç
Sony RDR HX750 HX950 Disassembly
Neye ihtiyacın var
  1. Sony RDR HX750 HX950 Disassembly, Remove cover: adım 1, 3 resimden 1. Sony RDR HX750 HX950 Disassembly, Remove cover: adım 1, 3 resimden 2. Sony RDR HX750 HX950 Disassembly, Remove cover: adım 1, 3 resimden 3.
    • Remove the screws from the back and sides of the top cover.
  2. Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: adım 2, 3 resimden 1. Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: adım 2, 3 resimden 2. Sony RDR HX750 HX950 Disassembly, Remove Hard Disk: adım 2, 3 resimden 3.
    • Remove the four screws that secure the hard drive mounting bracket to the bottom of the unit.
    • Unplug the two cables from the rear of the hard drive.
    • Remove the four screws from the bottom of the hard drive mounting bracket.
  3. Sony RDR HX750 HX950 Disassembly, Remove DVD player: adım 3, 3 resimden 1. Sony RDR HX750 HX950 Disassembly, Remove DVD player: adım 3, 3 resimden 2. Sony RDR HX750 HX950 Disassembly, Remove DVD player: adım 3, 3 resimden 3.
    • Remove the screws from the DVD cover
    • Remove the screws from the plastic cable holder
  4. Sony RDR HX750 HX950 Disassembly, Remove front Panel: adım 4, 3 resimden 1. Sony RDR HX750 HX950 Disassembly, Remove front Panel: adım 4, 3 resimden 2. Sony RDR HX750 HX950 Disassembly, Remove front Panel: adım 4, 3 resimden 3.
    • Insert the paper under each "click" to remove the front panel.
    • Once each "click" is loose, push the front panel gently.
    • The table of the compact disk has a little plastic piece in front that goes up to come out with a "click"
  5. Sony RDR HX750 HX950 Disassembly, Remove  DVD block: adım 5, 3 resimden 1. Sony RDR HX750 HX950 Disassembly, Remove  DVD block: adım 5, 3 resimden 2. Sony RDR HX750 HX950 Disassembly, Remove  DVD block: adım 5, 3 resimden 3.
    • Unplug the cables show in photo.
    • Disconnect the cable hidden on the side.
    • Remove the piece on the cd reader
  6. Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: adım 6, 3 resimden 1. Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: adım 6, 3 resimden 2. Sony RDR HX750 HX950 Disassembly, Remove cover of dvd player: adım 6, 3 resimden 3.
    • Under the DVD block, remove the screws as shown.
    • Remove the screws on the board.
    • Now the laser can be accessed.
  7. Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: adım 7, 3 resimden 1. Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: adım 7, 3 resimden 2. Sony RDR HX750 HX950 Disassembly, Sony RDR HX750 laser: adım 7, 3 resimden 3.
    • Inserir instruções aqui.
Sonuç
To open this dvd recorder folow this tutorial
2 farklı kişi bu kılavuzu tamamladı.
Cafony
687 İtibar
4 adet Kılavuz yazıldı
Bir Yorum
Hello,HX950 work only with hdd 250Gb,or another,with 500 or 1000Gb ???
Cornelus - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 61
Her zaman: 5,423
