Ana içeriğe geç
Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement
Neye ihtiyacın var
  1. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement, Sony Radio Model CFD S05 Prerequisite steps Replacement: adım 1, 1 resimden 1.
    • Unscrew the screws on the top of the radio.
  2. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: adım 2, 2 resimden 1. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: adım 2, 2 resimden 2.
    • Open the CD and cassette doors and remove the screws in the compartments.
    • To open the CD door push on the bottom left corner of the CD door. To open the cassette door push the button that is to the left of the pause button.
  3. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: adım 3, 1 resimden 1.
    • Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
  4. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: adım 4, 1 resimden 1.
    • Remove the top of the radio enough to access the wires for removal.
    • Do not forcefully remove the whole top piece of the radio! There will be wires connected to the top cover and circuit board.
  5. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: adım 5, 1 resimden 1.
    • Remove all of the wires that are connected to both the circuit board and the underside of the top of the radio by pulling them where they are connected
    • This should include three sets of red and white wires, one set of white wires, one set of black wires, and two ribbon wires. Some cannot be disconnected from the top piece of the radio. Disconnect these plugs from the circuit board.
  6. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement, Audio in Jack: adım 6, 1 resimden 1.
    • Unscrew the screws on the top right and top left of the back side of the buttons of the radio.
  7. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: adım 7, 1 resimden 1.
    • Pull out the buttons of the radio from the inside.
  8. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: adım 8, 1 resimden 1.
    • Pull out the audio in jack which is located on the right side of the radio directly below where the buttons are.
  9. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: adım 9, 1 resimden 1.
    • Remove the audio in jack from the circuit board by pulling on the wires where they are connected to the board.
  10. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: adım 10, 1 resimden 1.
    • Connect the new audio in jack wires to the circuit board where the old one used to be.
  11. Sony Radio CD player and cassette player CFD-S05 Audio in Jack Replacement: adım 11, 1 resimden 1.
    • Insert the new audio in jack into the hole on the back side of the front face of the radio.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Ian Nussman
959 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013 üyesi
UMASSD-GULBRANDSEN-F13S2G5
2 Üyeler
2 Yorum
En français cela serrais mieux
louis roy - Yanıt
Vielen lieben Dank für diese Info. Habe den Kasettenspieler erfolgreich repariert. Freut mich riesig. Danke danke!!! :-)
Bernhard Cronje - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 18
Her zaman: 2,990
