Ana içeriğe geç
Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement
Neye ihtiyacın var
  1. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement, Sony Radio Model CFD S05 Prerequisite steps Replacement: adım 1, 1 resimden 1.
    • Unscrew the screws on the top of the radio.
  2. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: adım 2, 2 resimden 1. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: adım 2, 2 resimden 2.
    • Open the CD and cassette doors and remove the screws in the compartments.
    • To open the CD door push on the bottom left corner of the CD door. To open the cassette door push the button that is to the left of the pause button.
  3. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: adım 3, 1 resimden 1.
    • Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
  4. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: adım 4, 1 resimden 1.
    • Remove the top of the radio enough to access the wires for removal.
    • Do not forcefully remove the whole top piece of the radio! There will be wires connected to the top cover and circuit board.
  5. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: adım 5, 1 resimden 1.
    • Remove all of the wires that are connected to both the circuit board and the underside of the top of the radio by pulling them where they are connected
    • This should include three sets of red and white wires, one set of white wires, one set of black wires, and two ribbon wires. Some cannot be disconnected from the top piece of the radio. Disconnect these plugs from the circuit board.
  6. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement, Belt for the Tape Motor: adım 6, 1 resimden 1.
    • Locate the motor of the radio on the underside of the top of the radio.
  7. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: adım 7, 1 resimden 1.
    • Unscrew the screw holding the motor to the top of the radio.
  8. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: adım 8, 1 resimden 1.
    • Lift up the motor.
    • Don't lift too high because the motor stand will break.
  9. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: adım 9, 1 resimden 1.
    • Unhook the larger band from under the motor and remove it.
  10. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: adım 10, 1 resimden 1.
    • Replace the band by hooking it beneath the motor.
  11. Sony Radio CD player and cassette player CFD-S05 Belt for the Tape Motor Replacement: adım 11, 1 resimden 1.
    • Push the motor back down and screw it into place.
    Nice... Worked for me and concise...... Now to find a belt. Thanks
    Tom - Yanıt
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Ian Nussman
959 İtibar
6 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013 UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013 üyesi
UMASSD-GULBRANDSEN-F13S2G5
2 Üyeler
Bir Yorum
I'm worried about removing wires. How do you put them back? Doesn't that take some kind of special equipment/glue?
Carolyn Farley - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 47
Her zaman: 5,016
