Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Open the CD and cassette doors and remove the screws in the compartments.
Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
Remove the top of the radio enough to access the wires for removal.
Remove all of the wires that are connected to both the circuit board and the underside of the top of the radio by pulling them where they are connected
Locate the motor of the radio on the underside of the top of the radio.
Unscrew the screw holding the motor to the top of the radio.
Unhook the larger band from under the motor and remove it.
3 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
I'm worried about removing wires. How do you put them back? Doesn't that take some kind of special equipment/glue?
