Ana içeriğe geç
Sony Reader Touch Edition PRS-600 Battery Replacement
Neye ihtiyacın var
    1. Sony Reader Touch Edition PRS-600 Battery Replacement, Back Panel: adım 1, 1 resimden 1.
      • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Reader Touch Edition PRS-600 Battery Replacement: adım 2, 1 resimden 1.
      • Slide the back cover off by pushing it to the left, away from the side that held the screws.
      • Remove the cover.
      FixBot'a Sor
      Yorum Ekle
    3. Sony Reader Touch Edition PRS-600 Battery Replacement: adım 3, 1 resimden 1.
      • This is what the device should look like once the back cover panel has been removed.
      FixBot'a Sor
      Yorum Ekle
    1. Sony Reader Touch Edition PRS-600 Battery Replacement, Battery: adım 4, 1 resimden 1.
      • Once the back cover has been removed locate the battery in the bottom right corner of the device.
      • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
      FixBot'a Sor
      Yorum Ekle
    2. Sony Reader Touch Edition PRS-600 Battery Replacement: adım 5, 1 resimden 1.
      • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
      FixBot'a Sor
      Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Terrika Ngobili
873 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-4, Benson Fall 2014 Clemson, Team 1-4, Benson Fall 2014 üyesi
CLEM-BENSON-F14S1G4
4 Üyeler
22 adet Kılavuz yazıldı
2Kılavuz Yorumları
It works great - thanks very much for this guide!
kitimatwoz - Yanıt Paylaş
where can i buy the battery for replacement ?? what battery is ? Answer me pls on: edgarjacob16@gmail.com
Edgar Jacob - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 83
Her zaman: 6,231
