Ana içeriğe geç
Sony Reader Touch Edition PRS-600 Battery Replacement
Neye ihtiyacın var
  1. Sony Reader Touch Edition PRS-600 Battery Replacement, Back Panel: adım 1, 1 resimden 1.
    • Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
  2. Sony Reader Touch Edition PRS-600 Battery Replacement: adım 2, 1 resimden 1.
    • Slide the back cover off by pushing it to the left, away from the side that held the screws.
    • Remove the cover.
  3. Sony Reader Touch Edition PRS-600 Battery Replacement: adım 3, 1 resimden 1.
    • This is what the device should look like once the back cover panel has been removed.
  4. Sony Reader Touch Edition PRS-600 Battery Replacement, Battery: adım 4, 1 resimden 1.
    • Once the back cover has been removed locate the battery in the bottom right corner of the device.
    • Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
  5. Sony Reader Touch Edition PRS-600 Battery Replacement: adım 5, 1 resimden 1.
    • Use the flat end of the spudger to pry the battery out of its holder. There may be glue holding it in place.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Terrika Ngobili
857 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-4, Benson Fall 2014 Clemson, Team 1-4, Benson Fall 2014 üyesi
CLEM-BENSON-F14S1G4
4 Üyeler
22 adet Kılavuz yazıldı
2 Yorum
It works great - thanks very much for this guide!
kitimatwoz - Yanıt
where can i buy the battery for replacement ?? what battery is ? Answer me pls on: edgarjacob16@gmail.com
Edgar Jacob - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 63
Her zaman: 4,641
