Neye ihtiyacın var
Using the Phillips head screwdriver PH000, remove the two 1.4 mm screws that are located on the backside of the device.
Once the back cover has been removed locate the battery in the bottom right corner of the device.
Using the pointed end of the spudger, push out the white plug that is connected to the battery from its beige base.
8 farklı kişi bu kılavuzu tamamladı.
2 Yorum
It works great - thanks very much for this guide!
where can i buy the battery for replacement ?? what battery is ? Answer me pls on: edgarjacob16@gmail.com
