Giriş
Identification
This lens can be identified by the markings “E 4.5-6.3/55-210 OSS” in addition to the model/serial number sticker.
Additional Links
Neye ihtiyacın var
Gently disconnect cable from ZIP connector.
Remove E-mount bezel.
Gently disconnect 3 cables from ZIP connector.
The two wider connectors open from the cable side, the thinner connector opens from the back side.
Remove 2 screws from lens park sensor.
Remove lens park sensor.
Remove 3 screws.
Pull lens out of external encasement.
Maneuver the telescope sensor so that it unmates from the slot in the internal lens body
Carefully feed the OSS/AF motor wire through the slot.
Remove 3 screws from the aperture end of the telescoping mechanism.
Lift lens to reveal and remove 3 brass/nylon nuts.
Remove 3 screws from the slide guides on the aperture end of the lens.
Remove 3 black nylon slide washers from the lens encasement.
Remove the OSS/AF mechanism.
Gently pull the cable up and out from the lens encasement groove.
Remove Kapton tape from aperture motor connector.
Disconnect aperture connector.
Remove 2 screws from aperture ring.
Remove aperture mechanism.
Disconnect 3 cables.
Remove 3 screws
Gently separate the OSS mechanism.
3 farklı kişi bu kılavuzu tamamladı.
2 Yorum
why did you need to dissasemble this lens. this lens looks similar to my 55mm lens which no longer focuses and the camera doesn’t recognize the lense anymore.
I need to know maddly, how can I have a reposition of the 6 spring there are on the first lense.
Is there any way?
If not, can you tell me specificcaly the size and the strength?
