Ana içeriğe geç
Sony SLT Alpha-65V Back Panel Disassembly
Salt Önkoşul
Bu sadece bir ön koşul kılavuzudur! Bu kılavuz başka bir prosedürün parçasıdır ve tek başına kullanılması amaçlanmamıştır.
Neye ihtiyacın var
  1. Sony SLT Alpha-65V  Back Panel Disassembly, LCD Screen: adım 1, 2 resimden 1. Sony SLT Alpha-65V  Back Panel Disassembly, LCD Screen: adım 1, 2 resimden 2.
    • Remove the two 4.0 mm Phillips #00 screws on the base of the camera.
    • Remove the 3.0 mm Phillips #00 screw on the hinge of the screen.
  2. Sony SLT Alpha-65V  Back Panel Disassembly: adım 2, 2 resimden 1. Sony SLT Alpha-65V  Back Panel Disassembly: adım 2, 2 resimden 2.
    • Remove the two 2.0 mm Phillips #00 screws on the bottom-right side of the screen.
    • Remove the two 2.0 mm Phillips #00 screws on the bottom-left side of the screen.
  3. Sony SLT Alpha-65V  Back Panel Disassembly: adım 3, 1 resimden 1.
    • Use the plastic opening tool to gently pry the screen open around the entire screen.
  4. Sony SLT Alpha-65V  Back Panel Disassembly: adım 4, 3 resimden 1. Sony SLT Alpha-65V  Back Panel Disassembly: adım 4, 3 resimden 2. Sony SLT Alpha-65V  Back Panel Disassembly: adım 4, 3 resimden 3.
    • The brown ribbon and white light on the edge of the screen are extremely loose and will fall off off. Keep the screen flat at all times to make sure they don't come out.
    • Use a plastic opening tool to disconnect the silver wires from the screen's circuitry and completely remove the screen from the camera.
  5. Sony SLT Alpha-65V  Back Panel Disassembly, Back Panel: adım 5, 1 resimden 1.
    • Unscrew the four 4.0 mm Phillips #00 screws with a on the base of the camera below the the scheme that separates the front and back panels.
    • Unscrew the 5.0 mm Phillips #00 screw on the bottom right of the camera.
  6. Sony SLT Alpha-65V  Back Panel Disassembly: adım 6, 1 resimden 1.
    • Unscrew the 4.0 mm Phillips #00 screw on bottom of the left side of the camera.
    • Unscrew the 5.0 mm Phillips #00 screw near the top of the left side of the camera.
  7. Sony SLT Alpha-65V  Back Panel Disassembly: adım 7, 1 resimden 1.
    • Be careful when pulling the back panel away as it will still be connected to the body of the camera by two strips of film.
    • When unscrewing the 5.0 mm screw on the dial, make sure to hold onto the dial that becomes detached after taking out the screw.
    • Unscrew the two 4.0 mm Phillips #00 screw at the top of the camera by the eyepiece.
    • Unscrew the 5.0 mm Phillips #00 screw of the dial below the other two screws.
    • Once all the screws are removed, carefully use your hands to detach the back panel from the camera. Working around the edges can help as well.
  8. Sony SLT Alpha-65V  Back Panel Disassembly: adım 8, 3 resimden 1. Sony SLT Alpha-65V  Back Panel Disassembly: adım 8, 3 resimden 2. Sony SLT Alpha-65V  Back Panel Disassembly: adım 8, 3 resimden 3.
    • Remove the two 4.0 mm Phillips #00 screws on the right of the camera that are located on the upper right side and under the "Remote" port flap.
    • Detach the right side panel with the remote and HDMI ports of the camera by gently pulling on the panel.
  9. Sony SLT Alpha-65V  Back Panel Disassembly: adım 9, 1 resimden 1.
    Bu adımda kullanılan alet:
    • When the back panel is removed, be careful when moving the camera. There are parts inside the camera which now may come loose.
    • Use tweezers to remove the blue and orange ribbon connectors from their connection points pictured here.
Sonuç
Dima Kyle
513 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-11, Amido Spring 2015 Cal Poly, Team 14-11, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S14G11
4 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 172
