Ana içeriğe geç
Sony SLT Alpha-65V LCD Screen Replacement
Neye ihtiyacın var
  1. Sony SLT Alpha-65V LCD Screen Replacement, LCD Screen: adım 1, 2 resimden 1. Sony SLT Alpha-65V LCD Screen Replacement, LCD Screen: adım 1, 2 resimden 2.
    • Remove the two 4.0 mm Phillips #00 screws on the base of the camera.
    • Remove the 3.0 mm Phillips #00 screw on the hinge of the screen.
  2. Sony SLT Alpha-65V LCD Screen Replacement: adım 2, 2 resimden 1. Sony SLT Alpha-65V LCD Screen Replacement: adım 2, 2 resimden 2.
    • Remove the two 2.0 mm Phillips #00 screws on the bottom-right side of the screen.
    • Remove the two 2.0 mm Phillips #00 screws on the bottom-left side of the screen.
  3. Sony SLT Alpha-65V LCD Screen Replacement: adım 3, 1 resimden 1.
    • Use the plastic opening tool to gently pry the screen open around the entire screen.
  4. Sony SLT Alpha-65V LCD Screen Replacement: adım 4, 3 resimden 1. Sony SLT Alpha-65V LCD Screen Replacement: adım 4, 3 resimden 2. Sony SLT Alpha-65V LCD Screen Replacement: adım 4, 3 resimden 3.
    • The brown ribbon and white light on the edge of the screen are extremely loose and will fall off off. Keep the screen flat at all times to make sure they don't come out.
    • Use a plastic opening tool to disconnect the silver wires from the screen's circuitry and completely remove the screen from the camera.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Alexander Lisso
618 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-11, Amido Spring 2015 Cal Poly, Team 14-11, Amido Spring 2015 üyesi
CPSU-AMIDO-S15S14G11
4 Üyeler
13 adet Kılavuz yazıldı
4 Yorum
hello everyone, thank you so much for this repair, I did that with my sony camera but it doesn’t work, how to know if its not the motherboard behind the screen that doesnt work or the flex cable, because the camera works perfectly just no screen, thank you in advance
Acèn - Yanıt
my father used to repair black and white tv in the 80's here in the country of PERU, so I thought, my father repairs tv I must have inherited the skill so I will repair my a77v camera, result = I messed up more xD.
At the moment the screen did not emit an image, it went all black, when I uncovered the screen I found a pcb which was missing a component, I started cleaning with a toothbrush and 2 more components came off, I could not identify if they are resistors, capacitors or diodes, I looked for the schematic on the web but I didn't find anything related, could you help me identify which components are missing? Is there a way to upload an image here to show where they came off? I will be very grateful, ATTE: a friend from Peru.
ruben omar mamani saga - Yanıt
Thanks for the Tutorial, I miss however the Part Number for a new disolay and maybe a source where to buy.
Regards
Willie
Wilfried Neumann - Yanıt
Das hat wunderbar funktioniert. Man darf nicht grob beim Aufschrauben sein, vor allen Dingen, wenn man das Gehäuse öffnet. Die Kabel darin sind sehr empfindlich. Vielen Dank! Die Displays gibt es für kleines Geld im Onlinehandel.
Heiner Klobbit - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 36
Her zaman: 5,765
