Ana içeriğe geç
Sony SRS-X5 USB/AUX plug in Replacement
Neye ihtiyacın var
  1. Sony SRS-X5 USB/AUX plug in Replacement, Battery: adım 1, 1 resimden 1.
    • To gain access to the 6 bottom screws remove the following. Remove the adhered 4 corner foam pads on the bottom of the speaker using the blue plastic opening tool to reveal the screws underneath. Remove the adhered 2 center plastic squares.
    • Make sure the speaker is unplugged and powered down before doing any work on the device.
  2. Sony SRS-X5 USB/AUX plug in Replacement: adım 2, 2 resimden 1. Sony SRS-X5 USB/AUX plug in Replacement: adım 2, 2 resimden 2.
    • Unscrew the six 6mm screws with a Phillips head #1 screwdriver.
    • Remove the bottom panel of the speaker.
  3. Sony SRS-X5 USB/AUX plug in Replacement: adım 3, 1 resimden 1.
    • Unplug the battery by gently pinching the plastic end connected to the smaller board and pull away.
    • Remove the battery.
  4. Sony SRS-X5 USB/AUX plug in Replacement, Speaker: adım 4, 1 resimden 1.
    • To remove the speaker grill, first push down slightly on the 2 plastic hook tabs to release them, then push the middle plastic screw tab out.
  5. Sony SRS-X5 USB/AUX plug in Replacement: adım 5, 1 resimden 1.
    • Remove the eight 0.5mm Phillips #1 screws from the speaker panel.
  6. Sony SRS-X5 USB/AUX plug in Replacement: adım 6, 2 resimden 1. Sony SRS-X5 USB/AUX plug in Replacement: adım 6, 2 resimden 2.
    • Using the plastic opening tool, flip open the speaker panel.
  7. Sony SRS-X5 USB/AUX plug in Replacement: adım 7, 3 resimden 1. Sony SRS-X5 USB/AUX plug in Replacement: adım 7, 3 resimden 2. Sony SRS-X5 USB/AUX plug in Replacement: adım 7, 3 resimden 3.
    • Unplug the 6-pin speaker connector and 2-pin microphone connector from the motherboard by squeezing the sides of the plastic ends.
  8. Sony SRS-X5 USB/AUX plug in Replacement, Bluetooth: adım 8, 2 resimden 1. Sony SRS-X5 USB/AUX plug in Replacement, Bluetooth: adım 8, 2 resimden 2.
    • Unplug the cord connected to the motherboard by squeezing the plastic sides.
  9. Sony SRS-X5 USB/AUX plug in Replacement: adım 9, 1 resimden 1.
    • Gently tug on the plastic ribbon connected to the bottom side of the speaker to unplug it.
  10. Sony SRS-X5 USB/AUX plug in Replacement: adım 10, 1 resimden 1.
    • Remove the motherboard.
  11. Sony SRS-X5 USB/AUX plug in Replacement, USB/AUX plug in: adım 11, 2 resimden 1. Sony SRS-X5 USB/AUX plug in Replacement, USB/AUX plug in: adım 11, 2 resimden 2.
    • Using the Phillips #1 screwdriver, remove the two 6mm screws holding the AUX board in place.
  12. Sony SRS-X5 USB/AUX plug in Replacement: adım 12, 1 resimden 1.
    • Remove the aux board. Be careful as the board might need some wiggling to get out.
Sonuç
Bir başkası bu kılavuzu tamamladı.
2 Yorum
hi there, where can i buy aux board for replacement? thank you
Khánh Trần - Yanıt
Donde puedo conseguir la tarjeta?
Alan Castaneda - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 1,634
