Ana içeriğe geç
Sony SRS-X55 I/O Board Replacement
Neye ihtiyacın var
  1. Sony SRS-X55 I/O Board Replacement, Battery: adım 1, 3 resimden 1. Sony SRS-X55 I/O Board Replacement, Battery: adım 1, 3 resimden 2. Sony SRS-X55 I/O Board Replacement, Battery: adım 1, 3 resimden 3.
    • Remove the six screw covers with a spudger.
    • Remove the six 11 mm Phillips screws from the bottom panel.
    • Remove the bottom panel of the speaker.
  2. Sony SRS-X55 I/O Board Replacement: adım 2, 1 resimden 1.
    • Disconnect the battery cable from the motherboard.
    • Remove the battery.
  3. Sony SRS-X55 I/O Board Replacement, I/O Board: adım 3, 2 resimden 1. Sony SRS-X55 I/O Board Replacement, I/O Board: adım 3, 2 resimden 2.
    • Remove the two Phillips screws from the I/O board.
    • Remove the front panel to the speaker by pushing on the two tabs in the corners.
  4. Sony SRS-X55 I/O Board Replacement: adım 4, 1 resimden 1.
    • Disconnect the ribbon cable from the I/O board.
    • Carefully remove the I/O board from the speaker.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Bradley Conner
169 İtibar
2 adet Kılavuz yazıldı
Bir Yorum
Where can i get a new i/o board?
Kyle Workman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 2,394
