Giriş
Follow this guide in order to replace the antenna to your device. The antenna is necessary in order for you radio feature to work on the device. If the antenna is broken, you cannot find signal to any AM/FM stations in your area.
Neye ihtiyacın var
On the bottom of the device, you'll see 4 rubber pieces at the corners. Peel off these rubber pieces.
Unscrew the 4 10mm Philips J1 screws beneath them.
Neredeyse bitti!
Bitiş Çizgisi
